Do the 902 MHz EnOcean and the 315 MHz EnOcean MPM's just have different antennas?
  • Do the 902 MHz EnOcean and the 315 MHz EnOcean MPM's just have different antennas?
  • BillNeville
    BillNeville
‎2018-09-06 09:24 AM
Cannot learn EnOcean thermostats into the MPM.
MPM, EnOcean
Purchased the wrong EnOcean frequency MPM. Can the antennas just be changed?
No, just replacing the antennas will not resolve the problem. The MPM controller and antenna must be replaced to match the frequency of the Enocean thermostats.
Note: the 315 MHz EnOcean MPM uses an antenna with green stripes; the 902 MHz EnOcean MPM uses an antenna with yellow stripes.
  • EcoStruxure Building Expert
  • 16785
