Disable Startup Items in Windows (XP to Windows 11)
  • Disable Startup Items in Windows (XP to Windows 11)
  • CraigEl
    CraigEl
‎2018-09-06 03:20 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-20 07:12 PM
Startup programs can slow down system boot time and cause application conflicts if loaded in the wrong order.
Andover Continuum, EcoStruxure Building Expert, EcoStruxure Building Operation, Satchwell BAS & Sigma, Satchwell MicroNet, TAC IA Series, TAC INET, TAC Vista
Windows XP, Vista, 7, 8, 8.1, 10, 11
Applications configured to launch at startup may:
  • Increase boot time
  • Cause system instability or delays
  • Load in an incorrect sequence, affecting performance
  1. Click Start → Run
  2. Type msconfig and press Enter
  3. Go to the Startup tab
  4. Uncheck items you want to disable
  5. Click Apply → OK
  6. Restart your computer
🔹 Windows 8, 8.1, 10, 11
  1. Press Ctrl + Shift + Esc to open Task Manager
  2. Click the Startup tab
  3. Right-click any item and choose Disable
  4. Restart your computer for changes to take effect
💡 Tip: Only disable items you recognize. Disabling essential services may affect system functionality.
Additional Notes
  • Disabling startup items is useful for troubleshooting slow boot times or software conflicts.
  • For persistent issues, consider using tools like Autoruns from Microsoft Sysinternals for deeper analysis.
Labels (8)
  • EcoStruxure Building Expert
  • Satchwell BAS & Sigma
  • Satchwell MicroNet
  • TAC IA Series
  • TAC INET
Tags (2)
  • 1384
  • CraigEllis25
100% helpful (1/1)
