Disable a program from another program with Script
  • Disable a program from another program with Script
  • GavinHe
    GavinHe
  • Alan_Wood
    Alan_Wood
‎2018-09-06 09:51 AM
Last Updated: Sisko GavinHe Sisko ‎2022-12-06 02:00 AM
At times it is necessary to programmatically disable a program from another program
  • EcoStruxure Building Operation Workstation
  • EcoStruxure Building Operation Server (ES/ASP/ASB)
A program will not just stop another program without some additional steps. In Continuum there was an ability to just name another program stop it.
A program can stop itself,  however, here is a way for one program to stop another program. The user can declare an input variable in a program, check it and stop the program, based on the value of that variable. That input variable would be set from outside the program.
Example: Prog1 stops Prog2
‘Prog1
Numeric Output OutStopProg    ‘bound to the input variable InStopProg of prog2
‘Stop program Prog2
OutStopProg = true        ‘this statement sets the input variable InStopProg  of Prog2 to true
‘Prog2
Numeric Input InStopProg     ‘bound to the OutStopProg variable of Prog1
If InStopProg = true then Stop   ‘this statement stops prog2 if InStopProg  is true
Tags (2)
  • 15062
  • GavinHeward23
