Determining the default IP address for a UNC, ENC, or Jace 8000
  • Determining the default IP address for a UNC, ENC, or Jace 8000
  • Cody_Failinger
    Cody_Failinger
  • RandyDavis
    RandyDavis
  • sesa116868
    sesa116868
‎2018-09-06 01:49 PM
Last Updated: Guinan RandyDavis Guinan ‎2022-04-06 05:47 AM
Documentation supplied with new UNC, ENC, or Jace 8000 was discarded.  Is there a way to determine the default, the factory-defined IP address, for the Ethernet port on the controller?
TAC IA Series
  • I/A Series (Niagara) R2 UNC
  • I/A Series (Niagara) G3 ENC
  • Niagara N4 or G3 Jace 8000
Lost or discarded document, shipped with the controller, that contained the configured IP address.
  • The default Ethernet IP address for an I/A Series (Niagara) UNC or ENC is based on the serial number and type of device. For a UNC or ENC, the default address is 192.168.1.14X where X is the last digit of the device serial number.  The default serial number is found on a sticker on the controller circuit board.  This sticker has the full model number, date code, and the serial number of the controller.  The serial number is preceded with S/N:.The subnet mask is 255.255.255.0 in all UNCs, ENCs, and Jace 8000
  • The default address base address (192.168.1.140) is the same for all UNC-410, UNC-510, UNC-520, ENC-410, and ENC-520 controllers.
  • The default IP address of a Jace 8000 for PRI (LAN1) is 192.168.1.140.  SEC (LAN2) is by default disabled.
  • TAC IA Series
Tags (2)
  • 5199
  • RandyDavis22
0% helpful (0/1)
