Deleting trends from External Log Storage is very slow and hangs Workstation
  • Deleting trends from External Log Storage is very slow and hangs Workstation
  • RandyDavis
    RandyDavis
  • JohnBoehmer
    JohnBoehmer
JohnBoehmer Schneider Alumni (Retired)
‎2021-07-13 08:14 AM
Last Updated: Administrator CraigEl Administrator ‎2021-07-13 05:55 PM
Deleting logs from External Log Storage takes a very long time.
Workstation becomes unresponsive when deleting trends from External Log Storage.
Building Operation Timescale Database
The deletion process can take a long time on large PostgrSQL databases, sometimes as much as an hour.
Workstation must complete the deletion process before it becomes available for other tasks.
When logged into Enterprise Server to delete a trend that was hosted by a child server (Automation Server), Workstation tags the log for deletion.  The AS that held the original log, will survey the trend_meta table every hour to check for pending flags, and will then delete logs that are flagged.  This can cause the deletion to be delayed by as much as an hour.
The following method should be used when deleting trends from External Log Storage:
  • The trend must no longer exist in EBO.
  • Log on locally to the server that hosted the associated trend.  Then deleted the trend from the System\External Log Storage folder.
  • Indexing the trend_data table can improve the speed of deletion dramatically in large PostgreSQL databases (1 TB or larger).
Tags (4)
  • Indexing
  • JohnBoehmer21
  • PostgreSQL
  • Timescale
