Decreasing network performance on TCP/IP layer. Direct Connections seem to work fine.
  • Decreasing network performance on TCP/IP layer. Direct Connections seem to work fine.
  • CraigEl
    CraigEl
‎2018-09-06 11:08 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 02:30 AM
TAC INET
I/NET
The network may be trying to communicate to IP addresses that do not exist
  1. Set devices to static IP
  2. Delete any old or unneeded Reference Hosts from all devices
  3. Clear Routing Tables. Both Routers (see Clearing IP address in the 527 routing table) and Workstations (see Viewing the routing tables on a PC using I/NET Seven)
  4. Use a network analyser or work with the building IT department to determine if the issue is IP Network Related
  5. Splitting Links to DLA will help remove load from routers
  • TAC INET
  • 1106
