Viewing the routing tables on a PC using I/NET Seven
  • Viewing the routing tables on a PC using I/NET Seven
  • Tom_Poovey
    Tom_Poovey
  • sesa145087_brid
    sesa145087_brid
‎2018-09-07 02:33 AM
Last Updated: Administrator DavidFisher Administrator ‎2020-10-26 02:43 PM
TAC INET
  • I/NET
  • Windows XP
Need to debug the I/NET routing table
Viewing the I/NET Routing Table
  1. Select Start>Run
  2. Type "regedit" and press enter
  3. Browse to HKEY_LOCAL_MACHINE>SOFTWARE>CSI – Control Systems International>I/Net 2000>Configurations. If you are using 64 bit operation system, the path should be HKEY_LOCAL_MACHINE>SOFTWARE>WOW6432NODE>CSI – Control Systems International>I/Net 2000>Configurations
  4. Select the folder corresponding to the active configuration profile
    Double Click on the parameter "DebugTables"
  5. Change the Value to "2"
  6. Click OK
  7. Close the Registry Editor
  8. Restart the computer
  9. To view the Routing Tables, right click on the I/O Server and select "Show Tables"
  • TAC INET
Tags (2)
  • 2889
  • inet
