Data Sync Service Configuration Tool unable to login and showing an Access is denied error
  • Data Sync Service Configuration Tool unable to login and showing an Access is denied error
  • RobertAndriolo
    RobertAndriolo
  • AdamSteele
    AdamSteele
Guinan AdamSteele Guinan
‎2022-10-25 05:00 PM
on ‎2022-10-25 05:00 PM
The Data Sync Service Configuration Tool is showing an error when attempting to connect to the Security Expert Data Service.
  • Failed to find operator where UserName = 'admin'. Exception: Access is deniedFailed to find operatorFailed to find operator
EcoStruxure Security Expert
  • Security Expert
The Authentication mode used by Security Expert is different from that used by SOAP. The Authentication mode selected during the installation of both software packages must be the same.
Authentication modeAuthentication mode
  1. Reinstall Security Expert or confirm the Authentication mode selected when it was installed. Consult the article Determining Security Expert authentication settings after installation.
  2. Reinstall Security Expert SOAP with the same Authentication mode used when Security Expert was installed.
  • EcoStruxure Security Expert
Tags (2)
  • AdamSteele22
  • AdamSteele24
