Creating an email alert when a controller is disconnected
  • Creating an email alert when a controller is disconnected
  • RandyDavis
    RandyDavis
  • JonGreen
    JonGreen
Commander JonGreen Commander
‎2020-12-15 12:22 PM
Last Updated: Guinan RandyDavis Guinan ‎2020-12-16 05:49 AM
Need an alert message sent out to notify when a controller disconnects from the network
Access Expert
  • Access Expert Controller
  • Access Expert Premise Software
  • Access Expert Hosted software
Controllers can potentially disconnect from the network. Knowing when can help troubleshoot the cause.
Having an alert based on a long time disconnect event can help to prompt an investigation.
  1. The time considered for this disconnect event is adjustable within the instance settings.2020-12-11_15-10-03.png
  2. Right-click the event "Controller Disconnected (Long Time) in event definitions and select view event history
  3. Right-click any of the events and select add Email template
  4. Create an email template using the pre-canned expressions and plain text2020-12-11_15-28-07.png
  5. Create an Alarm Action, select Notification when adding the action
  6. Fill out the template with the Email Template and who the recipients should be2020-12-11_15-30-39.png
  7. Create an Alarm Definition
  8. Assign Event type: Controller Disconnect (Long Time)
  9. Assign Alarm Action: Alarm action created in step 52020-12-11_15-35-20.png
  • EcoStruxure Access Expert
  • JonGreen20
