Creating a Custom Credential for an HID 37-Bit badge With No Site Code (H10302)
  • Creating a Custom Credential for an HID 37-Bit badge With No Site Code (H10302)
  • Brian_Feick
    Brian_Feick
  • David_Kendrick
    David_Kendrick
  • GavinHe
    GavinHe
  • JonGreen
    JonGreen
  • DavidChild
    DavidChild
Ensign Brian_Feick Ensign
‎2021-03-15 12:59 PM
Last Updated: Sisko GavinHe Sisko ‎2023-03-06 01:38 AM
There is no built-in Credential Type for the HID 37-Bit badge with no site code (H10302).
Security Expert
  • Security Expert Server
  • Access Card Format
Security Expert does not have the HID 37-Bit badge (H10302) with no site code as a built-in available Credential Type.
1) In the Security Expert Client, select Sites -> Credential Types2021-03-15_15-15-34.gif
2) Create a new Credential Type with a name of your choosing.
3) Under Configuration, select the Format as Wiegand.
4) In the field labeled Wiegand or TLV Format, enter the following exactly as written:                                                        A,FACILITY,0,MSB,BIN__B,CARD,35,MSB,BIN__PBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBP_EXXXXXXXXXXXXXXXXXX.................._..................XXXXXXXXXXXXXXXXXXO
5) Save
NOTE:
This article assumes that the reader is familiar with creating and deploying Custom Credentials, If this is not the case, then please reference the Complex Transition Programming section of the Transitioning Continuum Sites to Security Expert - Transition Guide
  • EcoStruxure Security Expert
Tags (3)
  • BrianFeick21
  • DavidKendrick21
  • GavinHeward23
