Create an internal Pulse Width Modulated (PWM) signal in Menta
  • Create an internal Pulse Width Modulated (PWM) signal in Menta
  • CraigEl
    CraigEl
‎2018-09-06 11:51 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 08:38 PM
A Macro comes installed in the default directories with Menta.  This macro will create a PWM signal that can be used for a variety of purposes in Menta.  It will not, however, drive most industry-standard PWM hardwired actuators.  For information on this, see Pulse Width Modulated (PWM) outputs in Menta.
TAC Vista
  • Menta
  • PWM actuator
Creating an a pulse width modulated output.
  1. Go to Program Files > TAC Menta > Library > Macro Block Library > Miscellaneous > Function > PWM.aut and PWM.doc
  2. These two files will give you a PWM function for Menta and an explanation.
  3. In simulation mode it will appear that the PWM increments at very crude levels but when the application is downloaded the processor actually runs at less than 1 second increments.
  4. Download this application to a controller and connect up a transducer and vary the control signal to be comfortable with the performance.
  5. Use a PVR block to generate a manually controlled signal.
  • 886
