Pulse Width Modulated (PWM) outputs in Menta
  • Pulse Width Modulated (PWM) outputs in Menta
‎2018-09-07 11:06 PM
Last Updated: Crewman ContentModerator ‎2025-10-10 02:53 AM
Create a true PWM output from a Xenta programmable controller using a DOPU block in Menta.
Menta
Menta does not have a built in PWM functionality, so to control a PWM actuator, some additional programming is required to utilize a DOPO block as desired.
  1. Click the image above to download the Menta Macro.
  2. Load the macro into the Menta file.
  3. The HFB takes a percent signal input and outputs the required values to control a DOPU block, which in turn will pulse the physical DO on the Xenta controller to control a PWM actuator.
PRCNT2PWM.zip
Tags (2)
  • 5063
  • configure
100% helpful (1/1)
