Create an alarm when a Modbus point has a specific value
  • Create an alarm when a Modbus point has a specific value
  • RobertAndriolo
    RobertAndriolo
  • Jonas_Brissman
    Jonas_Brissman
‎2018-09-06 09:25 AM
An analog Modbus value has specific values when the system is in error. For example:
  • 0 = No Error
  • 1 = Over Current Acc
  • 2 = Over Current DeAcc
  • 3 = Over Current Constant Speed
How could an alarm be defined to trigger when the object has Value = 2?
StruxureWare Building Operation 1.5
When using a Modbus analog value, it is not possible to create an alarm on a specific value.
Instead of a Modbus Analog Value, create a Modbus Multistate Input. With a Modbus Multistate Input, it is possible to connect a multistate alarm which gives the option to create an alarm on a specific value.
  • 16733
