Controlling command priorities with Continuum workstation programs or Infinity controller programs.
  • Controlling command priorities with Continuum workstation programs or Infinity controller programs.
  • GavinHe
    GavinHe
  • Carl_Slack
    Carl_Slack
  • Alan_Wood
    Alan_Wood
‎2018-09-06 02:10 PM
Last Updated: Sisko GavinHe Sisko ‎2023-01-13 02:23 AM
What is required to control command priorities in 3rd party controllers using Plain English?
Andover Continuum
  • Continuum Cyberstation
  • BACnet Controller (BCX, B4920, B3)
  • BACnet command priority
  • Plain English
Need to understand how to control command priorities and point values with Continuum workstation programs or controller infinity programs.
Command Priority is a BACnet mechanism to decide the control hierarchy of a point, with 1 being the highest priority and 16 being the lowest.  Consider the following:
  • Default setting for a workstation program priority level is ManualOperator priority 8
  • Programs located in the workstation default command priorities can be controlled through Bacnet Preferences
  • Controller InfinityPrograms will need to use the WriteProperty function to set a different priority other than priority 10
  • To relinquish a priority level use Relinquish(pointname, priority level)
The WriteProperty function is written in the format:
WriteProperty (object_name, value, priority, index)
object_name
  • Includes a full pathname, followed by a property name.
  • The object identifier and property identifier are combined as one argument
value
  • This actual value to which the property is set.
  • This is optional.  If it is not present, then the next argument, priority, must be present to perform a Relinquish command.  (See the example in Relinquish.)
 priority
  • The priority  number, ranging from 1 (highest) to 16 (lowest).This is optional.  It applies only to a set commandable property.
  •  For controllers:  If it is not present, priority 10, if applicable, is used.
  •  For CyberStation: The value, based on the priority in the BACnet Preferences dialog, is used.
 index
  • This is optional.  It applies only to an array-type BACnet property.  The index is ignored whenever it is not applicable.
Infinity controller samples:
This line will write the value of 22 to priority 10
BACnetDevices\BNet_4444\B3_885\B3Num1 = 22
This line will write the value of 33 to priority level 4
WriteProperty(BACnetDevices\BNet_4444\B3_885\B3Num1, 33 , 4 )
This line will relinquish the value for priority level 4 setting the value back to NULL
Relinquish(BACnetDevices\BNet_4444\B3_885\B3Num1 , 4 )
Tags (2)
  • 4542
  • GavinHeward23
