Control a door using the "Door Code" feature
  • Control a door using the "Door Code" feature
  • Tom_Poovey
    Tom_Poovey
  • Roger_Bently
    Roger_Bently
  • JohnBoehmer
    JohnBoehmer
‎2018-09-10 03:03 AM
Application is to open a door with a PIN Number instead of a card read.
I/NET Seven versions 2.4X and above.
The Customer is wanting to use a "PIN Only" function at a Pin Pad reader to gain access thru a door
The following document describes the procedure controlling a door using the Door Code Feature.
Door Code Setup Procedure.
  • TAC INET
  • 6218
