Continuum supports only one network card on workstations
  • Continuum supports only one network card on workstations
  • Cody_Failinger
    Cody_Failinger
  • Carl_Slack
    Carl_Slack
  • CraigEl
    CraigEl
‎2018-09-07 06:54 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 11:02 PM
Continuum worked fine and after a reboot of the workstation, now not receiving alarms and/or controller online/offlines.
Andover Continuum
  • Continuum Cyberstation
  • CX controllers
  • Continuum alarms
Communications issues between cyberstation and controllers.
Continuum supports only one network card (NIC) in a Cyberstation. Dual NIC configuration not supported.
Note: The issue with dual NIC is that when  PC is rebooted there is no guarantee which NIC will become #1 or #2. Please see Cyberstation Access Event Views do not show live events but work on other Cyberstations as well.
  • 4627
