Continuum runs very slowly, taking up to two minutes to first startup
  • Continuum runs very slowly, taking up to two minutes to first startup
  • AdamSteele
    AdamSteele
  • PaulFr
    PaulFr
  • CraigEl
    CraigEl
‎2018-09-10 12:20 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 06:50 PM
Continuum runs very slowly. Taking up to two minutes to first startup. Generally opening up Continuum Explorer and any other objects are seen to be slower than normal as well.
Andover Continuum
Continuum v1.94 and above
There was no Security Key connected and Continuum was running in Demo mode.
This symptom can also be caused by a missing or corrupt driver for the Security key, see Re-install of Continuum system and security key is not being recognized for details on re-installing the Security Key driver.
Install valid Security Key and restart Continuum.
Note: Want to know what features are supported in Demo mode? See How do we run Continuum in Demo mode and what features are available?
  • 8396
