Continuum Compatibility Matrix supersedes compatibility information on other documents.
  • Continuum Compatibility Matrix supersedes compatibility information on other documents.
‎2018-09-06 01:09 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 02:37 AM
The CyberStation installation guide states that the Continuum DB Server can be run on a Windows 7 PC while the Continuum Compatibility Matrix does not. Which document is correct?
Andover Continuum
  • CyberStation
  • WebClient
  • ContinuumDB Server
There are a variety of documents that describe system requirements for various Continuum products, it is unfeasible to update system requirement information in each document every time a change occurs.
For this reason the Continuum Compatibility Matrix should be used as the ultimate word on Continuum products and controllers and the software and firmware that support them.
The Continuum Compatibility Matrix is the ultimate authority when it comes to hardware/software/firmware compatibility.
Tags (2)
  • 6443
  • CraigEllis19
34% helpful (1/3)
