Connect eComission SmartX controller to a SmartX controller with no WiFi or Bluetooth available
  • Connect eComission SmartX controller to a SmartX controller with no WiFi or Bluetooth available
  • CraigEl
    CraigEl
  • Jonas_Brissman
    Jonas_Brissman
Janeway Jonas_Brissman Janeway
‎2021-09-27 11:24 PM
Last Updated: Picard RobertAndriolo Picard ‎2022-02-10 01:27 PM
Is it possible to connect eComission SmartX controller mobile application to a SmartX controller with no WiFi available in the building and BLE(Bluetooth) not turned on in the SmartX controller.
  • Building Operation eCommisioning Tool
  • Building Operation Room Controller (RPC)
  • Building Operation Multi-purpose Controller (MPC)
The eCommission SmartX controllers mobile application supports device
connection through BACnet Wi-Fi and wireless Bluetooth connection.
Install eCommission SmartX controllers on a computer, connect to the SmartX controller using an IP cable connected directly from the computer to the SmartX controller and enable Bluetooth on the SmartX controller.
  1. Disconnect IP cable from the SmartX controller if there is one connected.
  2. Restart the SmartX controller, since it can’t reach the DHCP server it will get an IP address in the range of 169.254.x.x.
  3. Make sure the computer IP address is in the same IP range as the SmartX controller.
  4. Connect the IP cable directly from the computer to port 2 in the SmartX controller.
  5. Start eComission SmartX controller mobile application and connect to the SmartX controller.
For details please see the video.
  • JonasBrissman21
100% helpful (1/1)
