Configuring a Xenta 527/NPR - Combo
  • Configuring a Xenta 527/NPR - Combo
  • RobertAndriolo
    RobertAndriolo
  • sesa139513
    sesa139513
  • Roger_Bently
    Roger_Bently
‎2018-09-06 03:05 PM
Last Updated: Picard RobertAndriolo Picard ‎2024-12-11 05:50 PM
TAC INET
  • I/NET site with a Xenta 527
  • End of Commercialization of TAC INET Building Management System Products
How to configure a Xenta 527/NPR - Combo
When setting up a Xenta 527 NPR or Combo Unit for the first time, there are six basic steps to commissioning the Xenta 527/NPR-Combo. These steps are described below.
  1. Connect the Xenta 527/NPR-Combo to 24 VAC power.
    Refer to the TAC Xenta 527 Installation Instructions (0FL-3956).
  2. Connect a PC to the Xenta 527/NPR-Combo. Attach a serial cable from the computer’s COM port to the RS-232 B port on the front of the Xenta 527/NPR-Combo. Refer to TAC Xenta 511/527/911/913 Handbook (0-004-7870) for complete instructions.
  3. Set the Xenta 527/NPR-Combo's communication parameters. Start a Hyper Terminal Session on your PC. Once the cable is connected, it will display the 527's default information.
    Note: The factory default login/password is root/root, at the dsh> prompt, type inethost then enter.
  4. Now add your I/NET information for reference host, etc.
  5. Restart the unit, when the "dsh>" prompt appears, type setip then enter this command will let you set its IP address and other basic parameters.
    Note: Refer to TAC Xenta Server Manual - TAC Xenta 527/NPR-Combo Supplement (0-004-7682-1) Chapters 3 & 5 for instructions.
  6. Once completed restart the unit again.
  7. Connect the Xenta 527/NPR-Combo to the Ethernet. Attach the Xenta 527/NPR-Combo to the network at the necessary location. Refer to Chapter 4, “Connecting the Xenta 527/NPR-Combo to your Network.
  8. Now ping the unit through the cmd prompt on your PC to verify that communications is taking place on the Network.
  9. If necessary, load the Xenta 527/NPR-Combo’s software.
    Note: The Xenta 527/NPR-Combo is delivered from the factory with preloaded software. If you need to reload this software, you can download it from the EcoXpert website. Before installing downloaded software, review its release information to verify compatibility with your hardware.
  10. Configure the Xenta 527/NPR-Combo to communicate with I/NET. In order for the Xenta 527/NPR-Combo to communicate with I/NET devices from across an Ethernet, you must first define basic communication parameters.
    Tip: You can now access the I/O configuration editor by opening NP Routers. From the Netplus Router Summary, select the router, modify it, and print the configuration for your records or the customers.
Once these steps are followed, your unit should be online, communicating to the Network, and seeing all your controllers at this site.
  • TAC INET
Tags (3)
  • 2044
  • RobertAndriolo24
  • Xenta 527-NPR
100% helpful (1/1)
