Cannot see a remote I/A Series BACnet/IP network while connected over a VPN connection.
  • Cannot see a remote I/A Series BACnet/IP network while connected over a VPN connection.
  • David_Kendrick
    David_Kendrick
  • sesa116873_brid
    sesa116873_brid
‎2018-09-06 01:14 PM
Last Updated: Sisko GavinHe Sisko ‎2023-05-03 06:11 AM
Connected to a remote site network via WorkPlace Tech and a VPN connection, but unable to see the sites BACnet devices. No I/A Series MNB-1000s, or any 3rd Party BACnet devices, are found in Workplace Tech or the Commissioning Tool.
TAC I/A Series
  • MNB-1000
  • WorkPlace Tech (all versions)
The VPN does place the connecting WorkPlace Tech PC on the site network, but the BACnet/IP (MNB-1000 and 3rd Party) devices are on a different subnet then the subnet assigned to the WorkPlace Tech PC.
When BACnet/IP devices are on different subnets, BBMD must be used in order for the BACnet/IP devices to communicate across IP subnets. Only one BACnet/IP device can be enabled as BBMD per subnet.
Setup the MNB-1000 as a BBMD device using the Commissioning Tool
  1. Open Device Properties of the MNB-1000 controller and select the IP tab.
  2. For Device Type select BBMD and save change.
Setup WorkPlace Tech to connect to the BBMD device
  1. Select Tool from the WPT
  2. Select Configure Communication…
  3. Select BACnet and click on Change
  4. Select IP and click next
  5. Select Access a remote internetwork.
  6. For Host BBMD Address, enter the IP address of the MNB-1000 which was setup as a BBMD device. Click the Finish button to save changes.
You should now be able to see and connect to the I/A Series and 3rd Party BACnet devices using WorkPlace Tech.
  • TAC IA Series
Tags (2)
  • 6272
  • DavidKendrick23
100% helpful (1/1)
