Can the red crosses (that indicate that a signal is offline) in Vista or SmartStruxure Workstation/Webstation be disabled?
  • Can the red crosses (that indicate that a signal is offline) in Vista or SmartStruxure Workstation/Webstation be disabled?
  • sesa139513
    sesa139513
  • LeeCravens
    LeeCravens
  • CraigEl
    CraigEl
  • sesa177673
    sesa177673
  • sesa125819
    sesa125819
‎2018-09-07 02:23 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-08 06:59 PM
EcoStruxure Building Operation, TAC Vista
  • SmartStruxure TGML Graphics (Workstation, Webstation)
  • Vista TGML Graphics (Workstation 5.X, Webstation 5.X)
When a signal which is bound to an object in a TGML graphic is offline, this is indicated by a red cross when viewing the graphic in Vista or SmartStruxure Workstation or Webstation.
This can easily be disabled in TGML by adding a script to the OnSignalChange event:
function signal(evt){
  evt.preventDefault();
Note, this script will only disable the red X when a point is offline. This does not address any issue that might cause points to be offline.
A short video is available on this process, to review, please see SmartStruxure - Graphics - Removing Red Crosses.mp4.
Labels (2)
Tags (5)
  • 1.4.1.2009
  • 4863
  • defect
  • hotfix
  • qc23935
100% helpful (2/2)
