Can a BAS2800+ UNC 532 Outstation Be Configured to Use a Modem and BAS 2800+ Terminal?
  • Can a BAS2800+ UNC 532 Outstation Be Configured to Use a Modem and BAS 2800+ Terminal?
  • CraigEl
    CraigEl
  • sesa125819
    sesa125819
‎2018-09-10 12:43 AM
Last Updated: Administrator CraigEl Administrator ‎2025-10-07 11:22 PM
Configuring a UNC 532 outstation to operate with both a modem and a BAS 2800+ terminal presents challenges due to hardware limitations.
Satchwell BAS & Sigma
  • BAS 2800+
  • UNC 532
  • Modem
The UNC 532 controller has shared UART communication ports, which restrict simultaneous use of a modem and a BAS 2800+ terminal when the controller is connected via LAN. This is due to the internal architecture where Channel 3 becomes unavailable in networked mode.
LAN-connected configuration:
  • Channel 3 is disabled.
  • Modem and terminal cannot be used together.
  • Refer to the Node Configuration window:
    • PL3 = Port 3
    • PL4 = Port 2
Standalone configuration:
  • Modem and BAS 2800+ terminal can be configured together.
  • This setup bypasses LAN restrictions and allows full use of UART channels.
  • Satchwell BAS & Sigma
Tags (2)
  • 5864
  • CraigEllis25
