Can Sigma Devices Be Connected to a Cat7 Ethernet Network?
  • Can Sigma Devices Be Connected to a Cat7 Ethernet Network?
  • CraigEl
    CraigEl
  • sesa139513
    sesa139513
  • sesa125819
    sesa125819
‎2018-09-06 10:26 AM
Last Updated: Administrator CraigEl Administrator ‎2025-10-21 06:21 PM
Can Sigma devices be connected to an Ethernet Cat7 network?
Satchwell BAS & Sigma
Satchwell Sigma
There is uncertainty regarding the compatibility of Sigma devices with newer Ethernet cabling standards, particularly Cat7.
Yes, Sigma devices can be connected to a Cat7 Ethernet network, provided that the network switches support 100 Mbps (100Base-T) communication.
Sigma devices typically operate at 100 Mbps, which is well within the capabilities of Cat5e, Cat6, and Cat7 cabling. The key factor is not the cable category itself, but whether the network infrastructure (especially switches) supports the required communication speed.
Cable Category Overview
Cable Type Frequency Max Speed Shielding Notes
Cat5/5e 100 MHz Up to 100 Mbps Unshielded Common in older installations
Cat6 250 MHz Up to 1 Gbps Improved insulation Suitable for Gigabit Ethernet; max 55m for 10 Gbps
Cat7 1000 MHz Up to 10 Gbps Shielded (per pair and overall) Enhanced protection from interference and crosstalk
Key Considerations
  • Ensure network switches are configured to support 100 Mbps communication.
  • Cat7 cables offer superior shielding and higher frequency handling, but do not inherently improve Sigma device performance beyond their 100 Mbps capability.
  • Using Cat7 may be beneficial in environments with high electromagnetic interference (EMI), but it is not a requirement for Sigma devices.
  • Satchwell BAS & Sigma
Tags (2)
  • 13156
  • CraigEllis25
