Can Modbus TCP and Modbus Async be used simultaneously in an ENC-520?
  • Can Modbus TCP and Modbus Async be used simultaneously in an ENC-520?
  • RyanSuar
    RyanSuar
  • RobertAndriolo
    RobertAndriolo
‎2018-09-06 10:50 AM
I/A Series G3 ENC-520 Modbus Integration
Modbus TCP integration and Modbus Async integration are both required from a single ENC-520
Yes, you can license an ENC-520 for both Modbus TCP and Modbus Async and run them in a single ENC.
  • TAC IA Series
  • 11973
