Cable to communicate with the NPR 2000 via serial port
  • Cable to communicate with the NPR 2000 via serial port
  • sesa139513
    sesa139513
  • CraigEl
    CraigEl
‎2018-09-06 11:24 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 02:04 AM
What is the correct cable to use to communicate with the NPR 2000 via its serial port?
TAC INET
I/NET Site
The getting Started book incorrectly specifies that you may connect the com port of the computer to the com port of the NPR 2000 using a standard serial cable.
The correct cables are the same cables used to connect to a 77xx01 emutap, the CBL072. Cable Connectivity to I/NET has more information on this cable.
  • TAC INET
  • 1375
