Building Expert unable to complete loading process
  • Building Expert unable to complete loading process
  • Cody_Failinger
    Cody_Failinger
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-11 10:07 AM
Building Expert unable to complete the loading process. The Building Expert interface will begin to load but gets stuck at a certain point and never finishes when trying to log into an MPM.
EcoStruxure Building Expert
  • Building Expert
  • SmartStruxure Lite
The web browser cache is full.
In order to get Building Expert to finish loading try the following tasks:
  1. Clear the cache of the web browser (To clear the cache in Firefox press CTRL-F5). Try loading Building Expert again.
  2. If clearing the web browser cache does not work then try performing a File System Format. Using the Application Note here, access the bootloader and perform a "File System Format". After this process has been completed then the firmware will need to be reloaded into the MPM.
  • EcoStruxure Building Expert
Tags (5)
  • 16654
  • download
  • framework
  • login
  • obix
