BAS2800+ – Can a USB to Parallel Converter Be Used for the Dongle?
  • BAS2800+ – Can a USB to Parallel Converter Be Used for the Dongle?
  • CraigEl
    CraigEl
  • sesa125819
    sesa125819
‎2021-01-31 08:35 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-30 04:57 PM
Users attempting to use a USB to Parallel converter to connect the BAS2800+ dongle report that the dongle is not detected by the system.
Satchwell BAS & Sigma
Satchwell BAS 2800+
The BAS2800+ dongle relies on direct communication with a true parallel port. USB to Parallel converters do not replicate the full functionality of a native parallel port, resulting in the dongle not being recognized.
Despite multiple investigations, USB to Parallel converters are not compatible with the BAS2800+ dongle. To ensure proper operation:
  • Recommended Action:
    If the BAS2800+ terminal needs replacement, purchase a PC that includes a native parallel port or install a dedicated parallel port expansion card.
  • Alternative Option:
    If sourcing a PC without a parallel port, search online (e.g., via Google) for PCI or PCIe parallel port cards that are compatible with your system. These cards typically offer better compatibility than USB converters.
  • Satchwell BAS & Sigma
Tags (2)
  • 7488
  • CraigEllis25
