BAS 2800+ – How to Merge Index Files from Two Sites
  • BAS 2800+ – How to Merge Index Files from Two Sites
  • CraigEl
    CraigEl
  • sesa125819
    sesa125819
‎2018-09-06 12:26 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-21 11:45 PM
Users need to merge Index files from two separate BAS 2800+ sites, but the standard BasFiles tool does not support this directly.
Satchwell BAS & Sigma
Satchwell BAS 2800+
BasFiles, in its default mode, does not provide the functionality to merge Index files. A special launch switch is required to enable this feature.
To merge two BAS site Index files using BasFiles, follow these steps:
  1. Launch BasFiles in Merge Mode:
    • Click the Windows Start button.
    • Select Run.
    • Browse to the location of BasFiles.exe.
    • In the Run dialog, enter:
      BasFiles.exe scs
    • This command launches BasFiles in a special mode that enables the Merge option.
  2. Use the Merge Option:
    • Once BasFiles is running in merge mode, a new menu option labeled Merge will appear.
    • Select Merge to begin the process.
  3. Prepare Directory Structure:
    • Ensure the required directory structure exists before initiating the merge.
    • The tool relies on this structure to correctly combine the Index files.
Best Practices
  • Always back up existing Index files before performing a merge.
  • Validate the merged file in a test environment before deploying to production.
  • Satchwell BAS & Sigma
Tags (2)
  • 7894
  • CraigEllis25
