BAS 2800+ - Adding a "Short Form Edit" command to a User Menu.
  • BAS 2800+ - Adding a "Short Form Edit" command to a User Menu.
  • CraigEl
    CraigEl
  • sesa125819
    sesa125819
‎2018-09-06 01:26 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-21 12:36 AM
The "Short Form Edit" command is not available by default in the BAS 2800+ user interface, which may limit user customization and quick access to editing functions.
Satchwell BAS & Sigma
Satchwell BAS 2800+
The "Short Form Edit" command is not pre-configured in the default system setup and must be manually added to the user menu.
To add the "Short Form Edit" command to a user menu:
  1. Navigate to:
    System Setup → User Menus
  2. Create a New Command:
    • Select "New Command"
    • Fill in the command details as follows:
      • Menu Text: Short Form Edit
      • Executable Path: C:\BAS\BIN\BASPNTSF.EXE
      • Command Line Options: {Osn No} {Pnt No} sf
  3. Add the Command to Menus:
    • Once created, assign the new command to the relevant user menus where quick access is needed.
  • Satchwell BAS & Sigma
Tags (2)
  • 6160
  • CraigEllis25
