BACnet/IP port supported with EcoStruxure Building Operation
  • BACnet/IP port supported with EcoStruxure Building Operation
  • Mahmoud_Sayed
    Mahmoud_Sayed
  • sesa139513
    sesa139513
  • Derrick_Ratliff
    Derrick_Ratliff
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-10 12:44 PM
Last Updated: Administrator CraigEl Administrator ‎2023-03-31 07:41 PM
  • Building Operation Automation Server
  • Building Operation Automation Server Premium
  • Building Operation Automation Server Bundled
  • Building Operation Edge Server - Standard
Which BACnet/IP ports are supported with EcoStruxure Building Operation, and can there be more than one port?
By default, the BACnet/IP network uses UDP port 47808 (0xBAC0), this is adjustable higher or lower. The BACnet/IP network supports a single BACnet UDP port, Additional IP networks can be created in the BACnet system as long as each network has a unique identifier (network Id and name) and UDP/IP port number. Refer to: Creating an Additional BACnet IP Network (se.com) and Best Practices When Configuring BACnet IP Networks and BBMDs for EcoStruxure BMS Servers
Please note that BACnet/IP uses UDP as its transmission protocol. For more information read the BACnet/IP basic design criteria.
Tags (2)
  • 11011
  • MahmoudSayed23
100% helpful (3/3)
