Automation Server IP protection. Measures in the AS to protect the system in cases of network broadcast storm or DoS attacks.
  • Automation Server IP protection. Measures in the AS to protect the system in cases of network broadcast storm or DoS attacks.
  • RandyDavis
    RandyDavis
  • AbeMeran
    AbeMeran
  • RobertAndriolo
    RobertAndriolo
‎2018-09-06 09:05 AM
Last Updated: Guinan RandyDavis Guinan ‎2020-07-17 08:35 AM
What are the measures in the AS to protect the system in cases of network broadcast storm or Denial of Service attacks?
  • Building Operation Automation Server Premium
Offline alarms received after excessive network traffic observed.
The firmware in the AS will temporarily shut down its Ethernet connection when exposed to a broadcast storm or DoS attack in order to protect the application in terms of control programs and IO.
A side effect of this is that the communication to external IP devices is temporarily unavailable during the storm/attack.
The Automation Server will log the network storm event in its log journal file. (see screenshot below)
Tags (2)
  • 17707
  • AbeMeran20
100% helpful (2/2)
