All Script programs in the AS have status unloaded
  • All Script programs in the AS have status unloaded
  • RobertAndriolo
    RobertAndriolo
  • Jonas_Brissman
    Jonas_Brissman
  • Benji
    Benji
‎2018-09-06 09:09 AM
All Script programs in the AS have status unloaded. How do I get them working again?
Struxureware Building Operation 1.5.
A script program had an output binding that was linked to a PVR block in a Function block program. It looks like on the server boot up, the script engine tries to start up before the function block engine does and when an output of a script sees that the binding is null, it throws an exception and shuts down the script engine. This only seems to be a problem when binding a script programs output to any PV type in a function block program.
 Bind to a Numeric output instead of a PVR block in the function block program.
  • 17525
