Alarms Stop Being Routed to the Sigma Server After Extended Computer Inactivity
  • Alarms Stop Being Routed to the Sigma Server After Extended Computer Inactivity
  • CraigEl
    CraigEl
  • RyanSuar
    RyanSuar
‎2018-09-06 02:10 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-21 07:48 PM
After a prolonged period of computer inactivity, alarms are no longer routed to the Sigma Server. However, once a user interacts with any point in the Sigma System Manager, alarm routing resumes.
Satchwell BAS & Sigma
Satchwell Sigma
This issue is caused by the Power Management settings of the Network Interface Card (NIC) on the Sigma Server. Specifically, the setting “Allow the computer to turn off this device to save power” is enabled, which can disable the NIC during periods of inactivity, interrupting alarm routing.
To prevent the NIC from being powered down during inactivity, follow these steps:
  1. Open Network Connections:
    • Navigate to Control Panel → Network Connections.
    • Locate the Local Area Connection used by the Sigma Server.
  2. Access Network Adapter Settings:
    • Right-click the connection and select Properties.
    • Under the General tab, locate the “Connect using” section.
    • Click the “Configure” button next to the network adapter name.
  3. Modify Power Management Settings:
    • In the Properties window, go to the Power Management tab.
    • Uncheck the box labeled “Allow the computer to turn off this device to save power.”
    • Click OK to apply the changes.
  4. Restart the Sigma Server (if necessary) to ensure the new settings take effect.
  • Satchwell BAS & Sigma
Tags (2)
  • 4526
  • CraigEllis25
