Adjusting the size of a text field on a monitoring tab may cause the dashboard to freeze
Turn on suggestions Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Do you mean
  • Adjusting the size of a text field on a monitoring tab may cause the dashboard to freeze
  • Alan_Wood
    Alan_Wood
Picard Product_Support on ‎2018-09-06 09:41 AM
Dashboard may freeze when adjusting a text field smaller than the content on a monitoring tab
Windows 7
Earlier versions of firmware in the MPM may have this condition
Upgrade from version 2.8 to version 2.10 in the MPM
  • EcoStruxure Building Expert
Tags (5)
  • 15625
  • edit
  • lite
  • smart
  • sruxure
Did you find this article helpful? Yes No
