Adding and Configuring Access Expert Area Report
  • Adding and Configuring Access Expert Area Report
  • Ramaaly
    Ramaaly
Lt. Commander Ramaaly Lt. Commander
‎2023-07-07 06:51 PM
Last Updated: Administrator CraigEl Administrator ‎2023-07-07 06:55 PM
The Area Report shows a list of cardholders by first and last name along with the name of the Area that the cardholder is located in.
EcoStruxure Access Expert
Access Expert Hosted V3
Area Report is not included in Access Expert Reports by default
To Run an Area Report
  1. Select the 'Access Control' Tab.
  2. Select the "Reports" Button.
  3. Select "Add Report".
  4. Double-Click "Area Report"
  5. (OPTIONAL) Enter a Display Name if you would like to save this report configuration for later.
  6. (OPTIONAL) Enable "Include Child Folders" if you would like to include all people within an Enterprise
  7. Click "Generate" to run the report, or "Save & Generate"
  • EcoStruxure Access Expert
  • RamaAly23
