Account credential test.
  • Account credential test.
  • CraigEl
    CraigEl
  • BillNeville
    BillNeville
  • sesa116827
    sesa116827
‎2018-09-11 04:35 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-14 06:23 PM
When you're having issues with Continuum you need to check if the Windows account you are logging on with is part of the Local Administrators Group.
Andover Continuum
Windows XP
Windows Vista
Windows 7
Windows 2008 Server
Continuum 1.9X
Permission issues running or installing Continuum 1.9X
Download the attached TestUserAdmin.zip file unzip the TestUserAdmin.exe file to your Desktop
Open the Command window (DOS prompt) and run the TestUserAdmin.exe
The program will indicate if the logged on Windows user is a member of the Local Administrators Group or not.
TestUserAdmin.zip
  • 13358
