Access Expert Sub-Device Integration
  • Access Expert Sub-Device Integration
  • Roger_Bently
    Roger_Bently
Lieutenant Roger_Bently Lieutenant
‎2018-10-08 05:17 PM
Last Updated: Administrator CraigEl Administrator ‎2018-10-08 05:19 PM
Unable to connect Continuum I/O's to Access Expert
Access Expert
Win 8.1 and above on Version 3
The Continuum Integration has only been configured to bring in the AC-1 and AC-1 Plus door controllers as sub-devices.
There is no resolution, but the Continuum I/O's are simply not compatible with Access Expert. Use Mercury 16 In/Out boards for applications that require these types of devices.
  • EcoStruxure Access Expert
