Access Expert Mercury Controller Types and Features
  • Access Expert Mercury Controller Types and Features
  • Alan_Wood
    Alan_Wood
Admiral Alan_Wood Admiral
‎2022-10-20 08:19 PM
on ‎2022-10-20 08:19 PM
List of Mercury Controller Types and Features
EcoStruxure Access Expert
Access Expert V3 Hosted
Mercury Controller Types and features to use with Access Expert
Overview
Mercury controllers are an open architecture controller made by Mercury Security. Feenics currently supports the LP series boards, the series 2 and series 3 MR SIO series boards.
Mercury Controllers
  Equivalent Features
FN-C1501 EP1501
The EP1501 is an intelligent controller that is expandable up to 8 downstream SIO controllers and up to 16 MR51e network-ready door controllers (for a total of 17 doors/openings).
240,000 Cardholders
50,000 Transaction buffer
32 Access Levels per cardholder
2 Onboard Readers
1 SIO bus (note: connects via Reader Port 1)
FN-C3202 EP1502
The EP1502 is an intelligent controller for controlling two connected doors and managing up to 64 doors/openings.
240,000 Cardholders
2 Onboard Reader Ports
1 SIO bus
FN-C3200 EP2500
The EP2500 is an intelligent controller for managing up to 64 doors/openings.
600,000 Cardholders
2 SIO Buses
FN-C4502 EP4502
The EP4502 is an intelligent controller for controlling two connected doors and managing up to 64 doors/openings and complies with the BACnet standard.
2,000,000 Cardholders
2 Onboard Readers
2 SIO Buses
FN-LP1501 LP1501
The LP1501 is an intelligent controller that is expandable up to 8 downstream SIO controllers and up to 16 MR51e network-ready door controllers (for a total of 17 doors/openings).
240,000 Cardholders
255 Access Levels per cardholder
Supports up to 130 inputs and 130 Outputs
2 Onboard Readers
FN-LP3202 LP1502
The LP1502 is an intelligent controller for controlling two connected doors and managing up to 64 doors/openings.
240,000 Cardholders
Supports up to 520 inputs and 516 Outputs
1 SIO bus
FN-LP3200 LP2500
The LP2500 is an intelligent controller for managing up to 64 doors/openings.
600,000 Cardholders
Supports up to 1024 inputs and 1024 Outputs
2 SIO Buses
FN-LP4502 LP4502
2 Onboard Readers
2 SIO Buses
FN-M5-IC M5-IC
An intelligent control device for the replacement of the Casi PX, PXN and PXNplus CPU controller. The single controller supports up to 64 readers across multiple enclosures.
128 Access Levels per cardholder
FN-M5-ICS M5-ICS
A multi-device interface panel that is a direct retrofit of Software House’s Pro GCM module. A 64 reader capacity
600,000 Cardholders
Mercury - PW6K1IC Prowatch 6000
The PW6K1IC is an intelligent controller that is expandable up to 8 downstream SIO controllers and up to 16 MR51e network-ready door controllers (for a total of 17 doors/openings).
15,000 Cardholders
10,000 Transaction buffer
EP Controllers - End of Life
Feenics used to support the EP Series controllers, however, they have been replaced with the LP series.
Related article - Updating Mercury Firmware
https://community.se.com/t5/Building-Automation-Knowledge/Access-Expert-Updating-Firmware-on-an-SSC-...
  • EcoStruxure Access Expert
Tags (8)
  • Access Expert
  • AlanWood22
  • controller
  • EP
  • features
  • LP
  • Mercury
  • properties
