AS-P/B DHCP Server Configurability
Select a Country
  • AS-P/B DHCP Server Configurability
  • RandyDavis
    RandyDavis
  • JohnBoehmer
    JohnBoehmer
  • Alan_Wood
    Alan_Wood
  • Dave_Shore
    Dave_Shore
  • DavidChild
    DavidChild
Alan_Wood Leader
‎2021-02-23 07:26 AM
on ‎2021-02-23 07:26 AM
Webhelp and the Technical Reference Guide supply information for using the AS-P/B DHCP server option, however, a number of relevant questions have not been answered.
EcoStruxture Building Operation
  • Building Operation Automation Server Premium (AS-P 0.62 hardware)
  • Building Operation Automation Server Bundled (AS-B)
  • Building Operation SmartX IP Multi-purpose Controller (MP-X)
  • Building Operation SmartX IP Room Controller (RP-C)
  • Building Operation SmartX Controller IP-IO Series
There are typically a number of options to configure DHCP servers, but since the DHCP server included with the AS-P/B is very basic and NOT configurable, it's important to understand which options are and are not available.
Webhelp has some helpful information about the DHCP Server Options.
The AS-P/Bs built-in DHCP server assigns unrouted IP addresses within the range of addresses from 10.110.210.2 to 10.110.210.254. This was developed to allow for a quick configuration of a private MP-X/RP-C network.
The AS-P/B DHCP server can be disabled and another DHCP server can be used.
Here is a list of other questions and answers that may come up based on typical options in other DHCP servers:
  • Can the scope of the IP range be configured?
    There is no way to configure or limit the range of the standard IP address range or to have multiple scopes.
  • Can IP exceptions be configured?
    There is no configuration option to prevent the AS-P/B DHCP server from assigning a specific IP address. The AS-P/B DHCP server is unaware of static IP addresses, so if a switch or other device has a static IP set in the 10.110.210.2 to 10.110.210.254 range, you run the risk of having the AS-P/B DHCP server assign an IP address twice which can cause a number of issues.
  • Can a Default gateway be configured?
    Not configurable
  • Can a Subnet mask be configured?
    Not configurable
  • Is IP6 supported?
    No
  • Can lease types be configured?
    No
  • Can multiple DHCP servers be installed on the private LAN?
    No
  • Should MP-X/RP-C IP level devices only be hosted within the private AS-P/B network?
    Most site IT departments prefer that the BAS networks be isolated, however, if the network switch (Not the AS-P/B) is used for assigning DHCP IP addresses, it could hand out addresses to the AS-P/B and the MP-X/RP-C devices if they are on the same subnet.
    A managed (RSTP Enabled) switch can reside as a client to the AS-P/B. This is due to how the Private DHCP option is advertised. On-site IT departments may not want the switch on the customer's LAN so it is placed in the private AS-P/B network.
  • Does the AS-P/B DHCP server assign addresses to 3rd party devices?
    Yes, if the 3rd party device supports this. This would be a configurable option in the device.
Tags (5)
  • AlanWood20
  • as-b
  • DavidShore21
  • DHCP Server
  • mp-x
88% helpful (7/8)
