AC1/AC1A does not have alternate LED pattern
  • AC1/AC1A does not have alternate LED pattern
  • Alan_Wood
    Alan_Wood
  • CraigEl
    CraigEl
  • AbeMeran
    AbeMeran
‎2018-09-06 09:26 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 02:15 AM
Replaced an AC1Plus with an AC1 and the reader pattern is incorrect
Andover Continuum
  • Continuum
  • AC1
  • AC1A
The AC1/AC1A module only has 1 LED pattern which is Alternate LED pattern, there is no way to alter this.
See Description of LED patterns on access readers, and how to change them for description of LED patterns.
If a different LED pattern is required by the site then use an AC1 plus or an ACX57xx which gives the ability to use an alternate LED pattern. See Description of LED patterns on access readers, and how to change them for configuration.
  • 6453
