A local user logged in to an AS-P can access the system folder in the ES which the AS-P is connected to
  • A local user logged in to an AS-P can access the system folder in the ES which the AS-P is connected to
  • CraigEl
    CraigEl
  • Jonas_Brissman
    Jonas_Brissman
Janeway Jonas_Brissman Janeway
‎2022-10-02 05:21 PM
Last Updated: Guinan RobertAndriolo Guinan ‎2022-10-03 04:33 PM
When a local user belonging to the administrator group on an AS-P is logged in to the AS-P using Workstation the user can for example via a Link in a graphic access the system folder in the ES the AS-P is connected to.  The local user in the AS-P can even change the admin password on the ES.
How can this be avoided?
  • Building Operation Automation Server
In EBO v3.2.1 and later versions, it is possible to restrict access of the logged-in user to only the server that they are logged into, i.e. it is possible to prevent access to the ES\Servers folder when logged directly into an AS-P that is a sub server of the ES, thus preventing access to the whole system.
In the ES Control Panel open Security Settings:
Mark the option "Restrict root permission to logged in server"
Tags (2)
  • ecostruxure building
  • JonasBrissman22
