A generic error occurred in GDI+
  • A generic error occurred in GDI+
  • RobertAndriolo
    RobertAndriolo
  • CraigEl
    CraigEl
  • LeeCravens
    LeeCravens
  • Benji
    Benji
  • sesa150561
    sesa150561
‎2018-09-11 12:49 PM
When editing a TGML error A generic error occurred in GDI+ appears
EcoStruxure Building Operation, TAC Vista
  • StruxureWare Building Operation
  • TGML
  • Graphic editor
This issue occurs after you install security update 3045171. You experience a crash when you use Windows GDI+ to create text outline-based path objects on a computer that is running Windows 7 Service Pack 1 (SP1) or an earlier version of Windows.
Download the patch below from Microsoft
https://support.microsoft.com/en-us/kb/3065979
It has been noted that this patch do not solves all the issues, if you still have issues with other applications uninstall the security update KB3045171.
Labels (2)
  • 17998
