A Continuum combined keypad/reader works with a valid card swipe, but the keypad itself does not work
  • A Continuum combined keypad/reader works with a valid card swipe, but the keypad itself does not work
  • David_Kendrick
    David_Kendrick
  • Alan_Wood
    Alan_Wood
‎2018-09-06 02:12 PM
Last Updated: Admiral David_Kendrick Admiral ‎2022-11-14 03:16 AM
A combined keypad reader works with a valid card swipe, but the keypad does not work. The keypad does not allow a valid pin to be entered to engage the door output even though the door, area and personnel objects are setup correctly. This issue could also happen with a keypad only, without the combination reader.
Andover Continuum
  • Keypad
  • Keypad/Reader Combination
A keypad or keypad/reader combination can be ordered with the keypad output set to work in a number of different modes.  Continuum requires the output mode to be ordered as follows:
  • Buffer one key
  • add compliment
  • 8 bit message (Dorado) This is also known as 8 bit burst
A keypad that has a different configuration than this will not work with Continuum
1. Order a keypad or keypad/reader combination with the 8 bit burst output mode set
2. Contact the keypad manufacturer's technical support (Eg. HID), to see if they will send a Configuration Card that allows the output mode to be changed retrospectively in the field.
Tags (2)
  • 4478
  • DavidKendrick22
