64-bit operating systems with the Andover Continuum product line
  • 64-bit operating systems with the Andover Continuum product line
‎2020-09-16 07:14 PM
Last Updated: Crewman ContentModerator ‎2025-09-19 03:03 AM
Are 64-bit operating systems supported on the Andover Continuum product line?
Andover Continuum
  • CyberStation
  • webClient
Compatibility requirements for Andover Continuum with 64-bit operating systems
Release 1.93 and earlier:
  1. For all machines with CyberStation or webClient software installed, only operating systems running in 32-bit environments are supported. 64-bit environments are not supported.
  2. However, for the Database Server on a LAN system where no Cyberstation or webClient software is installed, a 64-bit version of Windows Server 2008 (SP2) or Windows Server 2008 R2 may be used on systems running V1.92 and above. These will also require Microsoft SQL 2008 running in 64-bit mode.
Release 1.94 and later:
Release 1.94 supports 64-bit Operating Systems, however, Microsoft recommends the 32-bit version of Office 2010 because it prevents potential compatibility issues with other 32-bit applications, specifically third-party add-ins that are available only for 32-bit operating systems.
Please refer to the release notes for compatibility notes in specific versions.
Tags (2)
  • 4514
  • CraigEllis20
100% helpful (1/1)
