230 Volt Relay output module for SE7000 controllers
  • 230 Volt Relay output module for SE7000 controllers
  • Ramaaly
    Ramaaly
  • SESA150559
    SESA150559
‎2018-09-06 11:04 AM
Last Updated: Lt. Commander Ramaaly Lt. Commander ‎2022-04-05 07:21 AM
Sometimes, switching 230V with the SE7000 controller is requested and/or necessary, but no such product is listed in the current portfolio.
EcoStruxure Building Operation, EcoStruxure Building Expert
• Building Operation Workstation
• Building Operation Automation Server
• SSL SE7000
No product that matches the requests are currently listed in the portfolio
Two relay boards for fan coil units will be released late 2012.  These will allow the SE7000 devices to be used with 230V systems.
Labels (2)
  • EcoStruxure Building Expert
  • Field Devices
Tags (2)
  • 11241
  • RamaAly22
