Replacing an Automation Server (SW 1.5) with an AS-P (SW 1.9)
Ask the Community
Ask questions, get advice from experts and peers on Digital Automation & Energy Management.
  • Support
  • Replacing an Automation Server (SW 1.5) with an AS-P (SW 1.9)
CraigEl
Administrator CraigEl Administrator
35
chris_clerc
Administrator chris_clerc Administrator
8
MikaelKrantz
Guinan MikaelKrantz Guinan
7
Back to Ask the Community
nagaralesb
Crewman nagaralesb
Crewman
Posted: ‎2023-10-09 04:36 AM
1335
How to replace Automation server (SW 1.5) with an AS-P (SW 1.9)?
CraigEl
Posted: ‎2023-10-09 04:14 PM
1320
@nagaralesb sorry I misunderstood your request, I thought you were replacing an AS 1.5 with an AS-P and wished to upgrade to 1.9.
The AS-P was not released until 1.7.2 so earlier versions have no knowledge of it and it cannot be used. See the following lines I have highlighted from the Knowledge base article I previously linked.
Replies 6
CraigEl
Posted: ‎2023-10-09 05:06 AM
1331
https://community.se.com/t5/Building-Automation-Knowledge/Replacing-an-Automation-Server-with-an-AS-...
nagaralesb
Crewman nagaralesb
Crewman
Posted: ‎2023-10-09 07:06 AM
In response to CraigEl
Dear Sir,
I tried as per below link but not able to degrade the firmware from 1.9 to 1.5,  DFU mode failed.
CraigEl
1321
nagaralesb
Crewman nagaralesb
Crewman
Posted: ‎2023-10-10 02:20 AM . Last Modified: ‎2023-10-10 03:17 AM
Dear Sir,
Thank you so much.  It means there is no option to degrade 1.5 right?
CraigEl
Posted: ‎2023-10-10 03:30 AM
1307
@nagaralesb correct, an AS-P cannot be used in a system below 1.7.2
You should also be aware that these are very old releases and no longer supported, you shoulkd upgrade to a supported release if possible.
nagaralesb
Crewman nagaralesb
Crewman
Posted: ‎2023-10-10 03:36 AM
Dear Sir,
Okay, Thank for your support.
