Micom P14 lockout 8c0f:0000
Ask the Community
Ask questions, get advice from experts and peers on Digital Automation & Energy Management.
  • Support
  • Micom P14 lockout 8c0f:0000
CraigEl
Administrator CraigEl Administrator
35
chris_clerc
Administrator chris_clerc Administrator
8
MikaelKrantz
Guinan MikaelKrantz Guinan
7
Back to Ask the Community
Posted: ‎2022-07-28 07:39 AM
4
1991
I have this lockout with the below code appearing from time to time.
8c0f:0000
What is the cause of this and how can it be resolved.
Replies 4
Omaelk
Janeway Omaelk
Janeway
Posted: ‎2022-08-02 07:42 AM
@AndreMelo, can you please support?
AndreMelo
Commander AndreMelo Commander
Commander
Posted: ‎2022-08-02 12:55 PM
1934
Hi @Anonymous user , please find below the error description it seems not to be a permanent error and a restart normally should solve that. However, if it persists it may indicate a issue and the CCC shall be contact.
0x8C0F0000 2349793280     The error code is related to the main sampling buffer.
When the relay samples a new set of analogue channels it puts the data in a 2 cycle buffer. This is done in an interrupt. Later the protection task runs and extracts data from the buffer, thus free up space for new samples. This maintenance occurs if the buffer becomes full, i.e. samples are put in faster than they are removed. The maintenance error and reboot clears out the buffer and allows the protection to restart. The relay runs a multitask operating system which switches tasks in and out. The sampling interrupt is one of the highest priority tasks and will always run, the protection task is also high priority but not the highest. Another task may have run for longer than expected preventing the protection task from running.
Posted: ‎2022-08-08 07:27 AM
In response to AndreMelo
1863
Thanks for the reply @AndreMelo .
A reboot does clear the fault but it has occurred about 4 times in the past year. I’ll keep monitoring.
I have another issue with the same relay but this has happened only once. It recorded a watchdog alarm and reboot itself to be operational again. Upon checking the maintenance events, i found:
maint type 26
Maint data 0xFFFB0000
I can’t seem to find any interpretation of this in the manual.
Can you please assist with this.
Thanks a lot.
Regards
Aaron
AndreMelo
Commander
Posted: ‎2022-08-09 10:49 PM
In response to Anonymous user
Hi @Anonymous user,
Unfortunately, this second error code is not in my error code list. In this case, you shall open a ticket on your local CCC.  It can be a consequence of the sampling error your relay is presenting.
Best Rgards
