Ask questions, get advice from experts and peers on Digital Automation & Energy Management.
Posted: 2022-08-30 03:24 AM
Hello, is it possible to know how much time is left on a delay programming block?
For example, if I set the "DelayOff" property to 900s, so the output signal stays on for 15 minutes after the input signal is off, how can I know how much time is left? We found this problematic doing tests with physical signals.
Thanks in advance.
Posted: 2022-08-30 03:34 AM
Nope, sorry, that is not possible.
However, you could do a new timer, there you set the counter public, by using blocks to count, that is not using the DELAY block.
Posted: 2022-08-31 12:56 AM
What a bummer...
For me this was the easiest way to fix the issue:
Thanks for the fast reply!
