MP-C input shows Maximum Values of Analog Sensors connected with them
Ask the Community
Ask questions, get advice from experts and peers on Digital Automation & Energy Management.
  • Support
  • MP-C input shows Maximum Values of Analog Sensors connected with them
CraigEl
Administrator CraigEl Administrator
35
MikaelKrantz
Kirk MikaelKrantz Kirk
7
Omaelk
Janeway Omaelk
3
chris_clerc
Administrator chris_clerc Administrator
2
Back to Ask the Community
Sparsh
Ensign Sparsh
Ensign
Posted: ‎2022-12-03 12:56 PM
725
Hello Everyone,
I am facing 1 issue in the MP-C 36A, in which i have connected Temperature sensors Xenta 1.8K, 0-10V Rh Sensor and Temperature sensor, After configuring the inputs, the Controller is reading the false values, the Temperature sensor is connected and configured at its Ub input but it shows -89.33degC temperature whereas on its terminals it shows 1.7kohms and similarly for the voltage signal it shows 0V, and it is same issue with every input point. Connections are correct and terminals are tighten properly.
Also I have noticed 1 thing that when i configured the input Uc1 as Voltage input it shows almost the exact value which was 6.5V and then gradually decreases towards 0, but at its terminals it was still showing the same value,
It is a new controller what could be the possible issue with it, and even the status LEDs are Healthy glowing in Green colour.
MikaelKrantz
Kirk
Posted: ‎2022-12-05 12:44 AM
Do you have a drawing how this is connected?
Sounds like there are no power to the sensors?
